Network Management
Highlighted
Airwave 8.2.9.0 WPA3_OWE
I have some IAP325 with version 8.4.0.3 managed by Airwave 8.2.9.0.
How can I configure WPA3_OWE for my Guest network?
If I have the AP as standalone, I can configure "opmode enhanced-open", but I can't find the option in Airwave.
Highlighted
MVP Expert
Re: Airwave 8.2.9.0 WPA3_OWE
We can enable WPA3 Transition under network setting in Group>Instant Config page
Pavan Arshewar | ACCP
If my post address your queries, give kudos and accept as solution!
NOTE: Answers and views expressed by me on this forum are my own and not necessarily the position of Aruba or Hewlett Packard Enterprise.
Highlighted
for WPA transition you have enabled WPA3-Personal in your Screenshot, but I only like to have enhanced open.
This is the config on a standalone AP:
In the end, I like to see the network with WPA3_OWE:
