Network Management
MVP
Airwave - Allow Reboot In Read Only (monitor mode)
Hi
On our Airwave setup I have enabled the allow reboot in monitor / read only mode.  This used to work when I went to the devices and then list and ticked/selected the device I could hit "reboot" and then scheduled a time or apply now.
I don't see this option anymore.  Version is 8.2.7.1
MVP
Re: Airwave - Allow Reboot In Read Only (monitor mode)
Please ignore or delete this I have just released it was actually a bug with my web browser not allowing me to scroll down the options far enough to see the "reboot" option.
Apologises
Frequent Contributor II
Browser's !! :-)
-If you got what you need with my answer please give kudos and mark it as solution.
