Network Management
Occasional Contributor I
Airwave: Is there a SNMP trigger for AP link Speed?
I've been tasked with checking APs deployed on our campus to make sure they're connecting at 1Gbps.  I've created a Report (Inventory: Model Summary & Devices) and can sort by ENET0_IN speed.
However, I was wondering if we could go one step further and create a trigger in Airwave if a Controller reports an AP has come up on a 10/100Mbps link.  Does anyone know if this is possible?
Frequent Contributor II
Re: Airwave: Is there a SNMP trigger for AP link Speed?
There is no specific trigger for Link speed, but you could try the ap usage trigger and see if that solve's your purpose, but i think it is like a threshold set in, any usage beyond that will trigger an alert. other than this, there is no link speed trigger. It would be a feature request.
-If you got what you need with my answer please give kudos and mark it as solution.
