Network Management
Highlighted
Airwave Legacy License Migration Process
Hi ,
Is the Migration of licenses possible from legacy aruba airwave to  new licensing ?
If yes ,please guide on the migration process of legacy airwave license  ( AWMS-PRO  AND AWMS-PRO-FR , AW-1000) based on legacy aruba airwave appliance to VM based on new airwave license scheme.
thanks
Accepted Solutions
Highlighted
Re: Airwave Legacy License Migration Process
There is no migration in particular needed when you move from an Appliance to a VM.
Make sure the License key and the new server have the same IP address. In case you are planning to change the IP on the new server you would have to regenrate the license key with new IP as the Permanant license is tied to the IP of the server.
Vishnu
If my post helped you, don't forget to give kudos ;)
View solution in original post
Highlighted
Contact Aruba TAC and Local Sales teams
All Replies
Highlighted
Vishnu
Highlighted
