Network Management
Airwave Management Platform 8.2.2.1 upgrade to 8.2.9.1
Good Day All
I am currently running Airwave Management Platform 8.2.2.1 and I would like to upgrade to 8.2.9.1
Can I upgrade directly to 8.2.9.1 or is there a specific upgrade "path" I need to follow?
MVP Guru
Re: Airwave Management Platform 8.2.2.1 upgrade to 8.2.9.1
Upgrade patch 8.2.2.1>8.2.7.1>8.2.9.1, upgrading directly to 8.2.9.1 may result in fail with lot of rpm dependencies.
Pavan
If my post address your queries, give kudos and accept as solution!
NOTE: Answers and views expressed by me on this forum are my own and not necessarily the position of Aruba or Hewlett Packard Enterprise.
Contributor II
The upgrade path is multi step upgrade as the version is nearly 3 years old and lot of changes are present in the newer release. The upgrade path should be : 8.2.2.1 > 8.2.4.1 (Please note with this version, we have restriced CLI access. Please refer to the release notes) > 8.2.6.0 > 8.2.8.1 > 8.2.9.1
