Network Management
Highlighted
Moderator
Re: Airwave SSL certificate
The error statement says that the cert bundle is missing the RSA key.
DTLS certs aren't the same as regular SSL certs.  SSL certs are for communication to the AMP UI through httpd and nginx.  While DTLS certs is for secure AMON that uses a different communication route created specifically for that feature.
Rob Gin
Senior QA Engineer - Network Services
Aruba Networks, a Hewlett Packard Enterprise Company
Highlighted
Occasional Contributor I
Hey Rob,
That's the question - why doesn't the system see the RSA key?  I have used several methods to create the bundle I include the key with them each time.  Is there a specific procedure to getting the bundle put together for a wildcard cert that I could use to get this working?
I've imported the same cert w key in the GUI under Device Setup - Certificates without an error, but I can't seem to tell it to use that cert for the HTTPS traffic.
Note that I can also attempt to import the cert without the key on the GUI and I get the Certificate file is missing private key error as expected.  The one with the key imports and shows up properly here, but gives the RSA error on the CLI.  Is it time for a support ticket?
Phillip Horn
Highlighted
Moderator
Validations are different between UI and CLI.  Probably best to open a TAC case at this point.
Rob Gin
Highlighted
FYI - my issue was resolved.  There was a bug:
bug #DE32144 in 8.2.7.1 version, patch file was released.
TAC applied the patch and recompiled the software, and the certificate is now active.
Thanks for the help.
Phillip Horn
View solution in original post
Highlighted
what if you use a 3rd party cert management tool to handle the CSR and you need to install both the cert and private key? I download both in the PEM file but you mention the file to install needs to just be the identity cert 9.crt). Can I also get the private key and root chain installed in some way using option 11?
Highlighted
Moderator
That'd be a feature request to handle that scenario.  We do have our own CSR route built, but not one that takes an external CSR private key.
If you need to go that route, support can assist to put the pieces into place, but a feature request should still be submitted.
Rob Gin
