Network Management
Contributor II
Airwave Upgrade ?
Current Airwave is running 8.2.3 and I would like to upgrade to 8.2.9.1
I've looked for a doc or guide for completing upgrade but have not found anything. I have concerns as this is a full read/write production box and would like to know if I need to step upgrade this to previous versions first or if I can go straight to the 8.2.9.1 version.
Thanks in advance for any information there may be out there.
MVP
Re: Airwave Upgrade ?
This link may be of help.
https://support.arubanetworks.com/Documentation/tabid/77/DMXModule/512/Default.aspx?EntryId=35413
Ajay Kumar Ravipati
ACMA (V8) | ACMP (V8) | CCENT | CCNA (R&S) | PAN-OS 8.0 ACE
MVP Expert
Upgrade from 8.2.3 >  8.2.4.1 > 8.2.7.1 > 8.2.9.1
If server reaches internet login in to 8.2.3 CLI with root credentials and run command
#start_amp_upgrade -v 8.2.4.1
Once upgrade done to 8.2.4.1, login to AMPCLI (From 8.2.4.x code root access is blocked) and choose Option 7
Upgrade
1 Upgrade AirWave Management Platform
2 Upgrade OS Kernel
b >> Back
Your choice: 1
Running Upgrade AirWave Management Platform
Local upgrade versions:
1. 8.2.4.1
2. None of the above.
Which version? 2
Enter desired version:8.2.7.1
follow same steps as above to upgrde to 8.2.9.1
Pavan Arshewar | ACCP
If my post address your queries, give kudos and accept as solution!
NOTE: Answers and views expressed by me on this forum are my own and not necessarily the position of Aruba or Hewlett Packard Enterprise.
