Network Management
Airwave and ClearPass
I would like to understand the concept to build the firewall rules. I need some help with that. My setup is as below:
Clearpass mgmt --- firewall -- airwave
clearpass data -- firewall -- airwave
some documentation says that ClearPass alwayse initate connection through data port if it is configured.
I would like to integrate ClearPass with Airwave so from the ClearPass log you can click to Airwave portal and follow the user in Airwave.
I have to write up the firewall rules but not sure if it is
Airwave -- Clearpass mgmt -- 161
clearpass data -- airwave -- 162
or
clearpass mgmt -- airwave -- 162
or
Airwave -- Clearpass data-- 161
if some one please explain that will be huge help.
Thanks in advance.
MVP Guru
Re: Airwave and ClearPass
https://community.arubanetworks.com/t5/Security/CPPM-data-port-and-mgmt-port/td-p/150802
link explains data and managment port usage.
Allows both 161 & 162 ports on your firewall,  161 port is used by Airwave for snmp get/set operation where as 162 port is used to receive CPPM syslog and events in Airwave.
Pavan
If my post address your queries, give kudos and accept as solution!
NOTE: Answers and views expressed by me on this forum are my own and not necessarily the position of Aruba or Hewlett Packard Enterprise.
