Network Management
Highlighted
Airwave and Procurve 4200vl backups
We have recently added over 250 switches to Airwave. Some of these switches are HP Procurve 4200vl series. I know they are NOT part of the supported devices, however does anyone know if I can set Airwave to backup the config on these switches. Airwave is not even able to SSH into the switches at the moment. I keep getting an Error stating: "Error (Telnet/SSH Error: (pattern match timed-out) in username or password prompt: Unable to negotiate a key exchange method )"
Airwave has the correct credentials and everything works on the supported device i.e 5400R and 2920's our current Airwave is 8.2.10.0
Thank You
Accepted Solutions
Highlighted
MVP Expert
Re: Airwave and Procurve 4200vl backups
We need root access to edit known host list only TAC have access. Document link which I shared in my previous post provides step what need to do done on both switch and SSH client.
Open TAC ticket.
Pavan Arshewar | ACCP
If my post address your queries, give kudos and accept as solution!
NOTE: Answers and views expressed by me on this forum are my own and not necessarily the position of Aruba or Hewlett Packard Enterprise.
View solution in original post
All Replies
Highlighted
MVP Expert
If SSH encryption key is not in know host list of Airwave this will fail.
Check this document link
https://techhub.hpe.com/eginfolib/networking/docs/switches/RA/15-18/5998-8151_ra_2620_asg/content/ch08s06.html
Highlighted
Is there a way to edit the known hosts file on Airwave 8.2.10.0 ?
Highlighted
MVP Expert
Open TAC ticket.
