Network Management
Contributor II
Airwave is not generating backup
Hi community:
The procedure of getting the nightly backup is taking too long time, there are days that even it doesn't generate. There is a way to improve this process? We need that backup to migrate the service to a virtual machine because it will give us a flexibility to increase the storage. the available space on the local storage is 53 GB available.
Regards
Karlink
MVP Guru
Re: Airwave is not generating backup
We have to look in to system perfromance and data retention intervals to suggest changes, I would recommand to open TAC ticket.
Pavan
If my post address your queries, give kudos and accept as solution!
NOTE: Answers and views expressed by me on this forum are my own and not necessarily the position of Aruba or Hewlett Packard Enterprise.
