Network Management
Contributor II
Airwave licensing question
Hey
Im looking to upgrade our Airwave with approx 350 units. When getting prices from distributers I get these lines added on:
H2YV4E Aruba 3Y FC 24x7 Airwave 1 Dev E-LTU SVC
H2YV3E Aruba 1Y FC 24x7 Airwave 1 Dev E-LTU SVC
When asking what these numbers give me, not even Aruba can give me a clear answer.
Does anyone here know ? Is it support or is it software ?, do you actually need it per device ?
Regards
Jon
MVP Guru
Re: Airwave licensing question
It is per device
Thank you
Victor Fabian
Pardon typos sent from Mobile
Thank you
Victor Fabian
Lead Mobility Architect @WEI
Contributor II
Yes I know its per device, but the question still remains?
Regards
Jon
MVP Guru
Does anyone here know ? Is it support or is it software ? Both included when you purchase support
do you actually need it per device ? Yes
https://www.arubanetworks.com/assets/ds/DS_arubacare.pdf
Thank you
Victor Fabian
Thank you
Victor Fabian
Contributor II
We are still talking about a virtual machine running on our hw, so none of these benifits apply. And as I see it, if you have one support license running you still have access to upgrade for the Airwave management.
9700,- USD in support cost just for being able to send a email if something happens with Airwave seems a little much, a total of 18.200,- USD with the license itself.
Im guessing its enough with one 3Y licensene and the rest without.
Regards
Jon
MVP Guru
Jon,
Drop an eamil to aruba-licensing@hpe.com for more details.
Pavan
If my post address your queries, give kudos and accept as solution!
NOTE: Answers and views expressed by me on this forum are my own and not necessarily the position of Aruba or Hewlett Packard Enterprise.
