Network Management
Upcoming community maintenance Oct. 27th through Oct. 29th
For more info click here
Highlighted
Occasional Contributor I
Airwave misconfigured devices actions
I have airwave installed and working with 22 switches aruba 2540/3810.
The other day surprisingly for me, airwave restored a backup on one of the switches and everything I had done via CLI was lost causing me problems in the network.
Why does this happen? how can prevend this?
I a CLI man... Airwave is for the end user.
Accepted Solutions
Highlighted
Re: Airwave misconfigured devices actions
Thanks Pavan,
what will happen if I change a switch from managed to monitor only and then perform CLI configurations?.
View solution in original post
Highlighted
MVP Expert
If you switch from manage to monitor mode, airwave will not manage your configuration it will only montior the devices. Any config changes you make in CLI will not get override by airwave server.
Pavan Arshewar | ACCP
If my post address your queries, give kudos and accept as solution!
NOTE: Answers and views expressed by me on this forum are my own and not necessarily the position of Aruba or Hewlett Packard Enterprise.
All Replies
Highlighted
MVP Expert
Airwave will push configuraiton if devices are placed in manage mode, in this mode we can not make any configuation changes in switch CLI.
Any changes done via CLI will be override by configuraiton file present in Airwave.
Highlighted
Thanks Pavan,
Highlighted
MVP Expert
