Network Management
Highlighted
Re: Airwave to 8.2.1.1 upgrade from 8.0.9.1: upgrade causes disconnect on the CLI almost immediately
Current Version: RELEASE_8_0_9_1
[root@localhost mercury]# psg upgrade
root 4826 0.0 0.0 133908 6028 pts/1 S+ 09:42 0:00 upgrade
root 4838 0.0 0.8 269956 68108 pts/1 S+ 09:42 0:00 upgrade
root 15300 0.0 0.0 133904 6012 pts/0 S+ 13:30 0:00 upgrade
root 15315 0.4 0.8 269976 68092 pts/0 S+ 13:31 0:00 upgrade
[root@localhost mercury]# cd /var/log/upgrade
[root@localhost upgrade]# ls
this is the result of the psg upgrade and the var/log/upgrade folder was empty.
Highlighted
Moderator
Its weird that it came up with 4 entries though.  It's a good idea to open a support case.  Also, try strace on those PIDs to see what they are doing.  Often times, the upgrade won't proceed if nightly_maintenance is still running.
Rob Gin
Senior QA Engineer - Network Services
Aruba Networks, a Hewlett Packard Enterprise Company
