Network Management
Highlighted
Airwave with 7210 controller - read/write mode
Hi community! I can not figure out how to turn 7210 controller from read only to read/write mode. Is this a Airwave restriction? only read mode for 72XX controllers? 7210 is using release 8.3. Thanks in advance. Regards.
Martín Rodriguez
Highlighted
Re: Airwave with 7210 controller - read/write mode
Did you see the Airwave controller config document here?  https://support.arubanetworks.com/Documentation/tabid/77/DMXModule/512/EntryId/32808/Default.aspx
ArubaOS 8.5 User Guide
InstantOS 8.5 User Guide
Airheads Knowledgebase
Airheads Learning Videos
Aruba Central Documentation
ArubaOS Consolidated Release Notes
Aruba VIA ASE Solution - Configure VIA VPN
Highlighted
Hi. I just read very carrefully the Supported Devices list. Configuration (management) is not supported on Aruba devices running AOS 8.0 or later. Only for AOS 6.5. Hard to belive. I hope this feature will be avaible soon (or not?). Thanks again for guiding me. Regards.
Martín Rodriguez
