Yes, we do not see that in 8.2.8.1 supported devices list , it means that we have not started supporting it yet. However, you can try adding the device as a Cisco WLC, to see the basic feature supported or you can add it as universal Network device, which will have basic, snmp monitoring.
-If you got what you need with my answer please give kudos and mark it as solution.
