Network Management
Contributor I
Airwave with ClearPass integration
What information can be shown by integrating airwave with clearpass ?
Can we see authentication requests like access tracker, users informations... ?
Airwave is added in clearpass as monitoring system and clearpass is added by device setup in airwave, is there any other configurations ?
MVP Expert
Re: Airwave with ClearPass integration
You should be able to monitor the health stats like CPU, Memory. Get device status alerts, syslog traps etc.
You wouldnt see the access tracker of clearpass on Airwave.
Vishnu
If my post helped you, don't forget to give kudos ;)
Contributor I
Thanks Vishnu.
So is there any way to see users information (authentication requests, enforcement profiles, roles of clearpass) inside airwave ?
MVP Expert
Airwave doesnt show the enforcement profile or roles from clearpass. Airwave is used only to monitor the Clearpass server. The specific data needs to be checked on Clearpass itself.
Vishnu
MVP Guru
See here:
https://community.arubanetworks.com/t5/Security/ClearPass-Tips-and-Tricks-AirWave-Diagnostic-Link/m-p/226319
if you have Aruba mobility controller you can also send additional information using Clarity
https://community.arubanetworks.com/t5/Network-Management/How-To-Getting-Clarity-Live-up-and-running-in-5-minutes/td-p/263716
Sent from Mail for Windows 10
Thank you
Victor Fabian
Lead Mobility Architect @WEI
Contributor I
thanks victor
