Network Management
Upcoming community maintenance Oct. 27th through Oct. 29th
For more info click here
Highlighted
Occasional Contributor I
Alert appears very slow
We are configuring for the first time the monitoring of an Aruba 5406R zl2 switch from ariwave.
Currently we have created some triggers to warn us when certain ports fall, and it is working, but since airwave detected in "syslog & traps" the problem until that appears in "alerts" spend 5 minutes.
Is it possible to change this?
Thank you.
Greetings.
Highlighted
MVP Expert
Re: Alert appears very slow
We can modifiy snmp polling intervals in Groups>Basic page but not syslog&trap interval.
Pavan Arshewar | ACCP
If my post address your queries, give kudos and accept as solution!
NOTE: Answers and views expressed by me on this forum are my own and not necessarily the position of Aruba or Hewlett Packard Enterprise.
Highlighted
How does airwave process a trap snmp that has a trigger associated?.
How long does it take to generate the alert?
Highlighted
MVP Expert
Airwave trigger alert immediately when it receive matching conditon data. Traps/syslog is forward by controller to server, if airwave is added as trap receiver in controller.
Using SNMP protocol it polls the controller depend on configured polling interval to get device data.
Highlighted
Hi pavan,
the configuration of the switch is as follow:
snmp-server community "airwave" unrestricted
snmp-server host 10.223.103.101 community "airwave" trap-level all
snmp-server enable traps vsf
snmp-server trap-source 192.168.201.15 (ip switch)
On the airwave:
I attach images.
As you can see in the images, the difference between the trap receipt and the alert, is 5 minutes.
Best Regards.
Highlighted
MVP Expert
What is the device UP/Down polling interval status in Groups>Basic page?
Highlighted
Hi Pavan,
I attached file.
Is correct?.
Best Regards.
Highlighted
Hi pavan,
Can you see the files and the config?.
Best regards
Highlighted
MVP Expert
Open TAC ticket to debug.
Highlighted
Hi Ruben,
Any particular reason why we have the default polling values changed? If not could we try setting it to default and check onces? Atleast the up/down polling to 5 from 15. Below is a screen shot from lab server with the default values.
Vishnu
If my post helped you, don't forget to give kudos ;)
