Network Management
Upcoming community maintenance Oct. 27th through Oct. 29th
For more info click here
Highlighted
MVP Expert
Re: Ambiguous supported devices by AirWave
Hi Pavan,
Thanks for your reply.
List of devices which are listed in HPE device section in support device guide have full support in airwave but we can add other model devices aswell in Airwave  to monitor with limited support.
1. Sure? Because in that case those devices should be listed aswell just with a note saying they have limited support, like in the case Cisco 2960, which is listed and with that note:
I see support for below model switches aswell and regarding 4500 series switch, we can add the device to airwave but with limited support.
AP_TYPE_HP_COMWARE_SWITCH_1910 => 645,
AP_TYPE_HP_COMWARE_SWITCH_1920 => 646,
 AP_TYPE_HP_COMWARE_SWITCH_1950 => 647,
2. Then, do you mean full support for 1910, 1920 and 1950 and limited support for 4500?
3. Is the 1905 supported?
Julián
