Network Management
Aruba S1500-24P
I do not know if this is the correct thread but I can't seem to find one dedicated to switch configuration.   My story goes like this.  My pastor purchased three HP Aruba S1500-24P Mobilty Access Switches.  This switches are intended for a standalone environment.  We can configure the switches just fine but when the switches reboot, it looses all of its settings and goes back to initial settings.  I have searched for a while now but I cannot find a solution.  My thought is that these switches require a Aruba-Central to work and pull their config.  Can I get this switches to save their configs and work as a standalone switch?
I have attached the initial running and startup configs.
Thank you,
Brad Foreman
Re: Aruba S1500-24P
Re: Aruba S1500-24P
Yes, I have tried write memory.   It tells it is successful.
(ForemanSwitch) (config) # enable secret
Password:*********
Re-Type password:*********
(ForemanSwitch) (config) #write mem
Saving Configuration...
Save failed: Admin password same as default password
Use "mgmt-user admin" command in configuration mode to change the admin password.
(ForemanSwitch) (config) #mgmt-user admin
% Incomplete command.
(ForemanSwitch) (config) #mgmt-user admin ?
<rolename>              Role name from one of the following:
                        root - super user role
                        guest-provisioning - guest provisioning role
                        network-operations - Network operator role
                        read-only - Read only role
                        location-api-mgmt - Location API Management Role
(ForemanSwitch) (config) #mgmt-user admin root
Password:*********
Configuration Saved.
But when I restart, it nevers saves it.
Brad
