Network Management
Highlighted
Aruba Switch 2930M SFP Module
Hello Community,
I just recently stacked two 2930M aruba switches.  I also installed a 10G SFP module that will not be recognized by the the switches.  I have ran a sh module command and only see the two stacking modules.  Am I supposed to run or enable the SFP module?  I also ran the sh int brief and don't see the addition fiber ports.  I'm also on the latest code that was just recently released in June 2019 WC.16.09.0001
Thanks.
Highlighted
MVP Guru
Re: Aruba Switch 2930M SFP Module
What SFP+ transceiver are you using? The Aruba switches will not show them as a module but as a transceiver:
sw01# show modules
 Status and Counters - Module Information
  Chassis: 2930F-8G-PoE+-2SFP+  JL258A         Serial Number:   *removed*
sw01# show interfaces transceiver
Transceiver Technical Information:
                     Product      Serial             Part
 Port    Type        Number       Number             Number
 9       SFP+SR      J9150A       removed.....       1990-4065
 10      1000T-sfp   J8177C       removed...         1990-3816
Do you see something with show interfaces transceiver?
