I am currently testing a few switches on AirWave 8.2.5.1 and everything in the template works but the %ip_address% and %netmask% variables. I have an IP address assigned to one VLAN on each switch. When I import the configuration from a switch to the template, it automatically creates all the variables, such as %hostname% and %gateway% but the IP address stays static. If I add the ip address %ip_address% %netmask% command to the template, all the switches become mismatched because the variables aren't recognized.
Any ideas what the issue is?
