Network Management
Highlighted
Change Airwave IP - fix /etc/sysconfig/network-scripts
I've just moved the Airwave to a different host (virtual) and I wasn't able to get the networking.
I've attached the screenshot, but basically It could find the phy(virtual) network adapter on the VM.
Is there any way to edit the /etc/sysconfig/network-scripts?
Accepted Solutions
Highlighted
Re: Change Airwave IP - fix /etc/sysconfig/network-scripts
If Airwave version is 8.2.4 or above you would have to contact TAC as it needs to be done from shell. Since its a VM migrated it might be holding the old MAC and the new instance might be having a different MAC. So, we might have to update it and or remove the persistant.d file and reboot the server.
Vishnu
If my post helped you, don't forget to give kudos ;)
View solution in original post
All Replies
Highlighted
Vishnu
