- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
08-31-2018 12:56 AM
We are using both PRTG network monitoring and Oxidized w/Gitlab for monitoring and network device backup.
I like Airware for Wireless units and see the updates in the last version regarding switches are getting much better. BUT.... are there still no support for Comware units like the 5700/5900 ?
It seems strange to me that I can add a old Proxim Tsunami wireless link to Airwave but not a expensive HPE product like the Flexfabric switches.
A lest there should be a option to add MIB files and settings.
Regards
J.
Jon
Solved! Go to Solution.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
Re: Comware units and Airwave 8.2.7
08-31-2018 01:10 AM
I'm not shure if you can add all of them but I monitor a 5940 in Airwave to show a proper topology. Edge switches are ArubaOS
You can add them in Airwave as HPE Officeconnect Switch.
rgds,
Erik
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
08-31-2018 01:25 AM
Dont now what wrong then. 5900 should equal the 5940.
AIrwave says down, and snmp failed. The configuration are correct. All other Provision and ArubaOS switches works as expected.
Thanks for the information Erik.
Jon
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
08-31-2018 01:31 AM
I had the same so opened a TAC.
Comware has default only 1 SNMP version enabled. dis snmp-agent sys-info version will tell you which one.
According TAC you can only have 1 SNMP version working but I found the command: "snmp-agent sys-info version all" to enable them all. Give that a try?
rgds,
Erik
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
08-31-2018 01:33 AM
Thanks Erik, I noticed this 1 minute before your post.
The Comware had snmp v1 and v3 enabled. My Airwave was set to v2c.
Thanks for the help.
Jon
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
3 weeks ago
I know this problem is a bit older.
But...so it is definetly possible to monitor 5700/5900 Series with airwave ?
After all, it is also Comware 7, right ?
But these series are still not mentioned in the offical doc:
Just these:
HPE 5120 Switch 2220P02 (Comware 7)
HPE 5130 Switch 2220P02 (Comware 7)
HPE 5500 Switch Series 2220P02 (Comware 7)
HPE 7500 Switch Series 2220P02 (Comware 7)
Regards
HPE 10500 Switch Series 2220P02 (Comware 7)
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
3 weeks ago - last edited 3 weeks ago
I can confirm that Flexfabric 5700 and 5900 are working.
In version 8.2.8.0 also baseline configuration is supported.
Jon
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
3 weeks ago
Monitoring 5900 series switches in Airwave works fine at this project. The switches are visible in the topology which was the reason I wanted to have them in Airwave.
I still have an issue with 5700 series. I get an error in Airwave: HPE OfficeConnect Switch Error in SNMP polling: Unknown error(interface_monitor) which I can't resolve or find any info on.
SNMP is configured exactly the same as the 5900 series and I see some info in Airwave: CPU Usage and Uptime. Switches do not appear in the topology and I don't see interface information.
It doesn't have a priority though since there are no AP's or Clients connected to these switches. Opening a TAC case is not possible for this since this phase of the project has ended and I have no access to the implementation until the next phase starts.
It would just have been nice to see these switches in the topology. I might remove them from Airwave altogether in the next phase of the project and save the licenses, unless someone can tell me what the difference is between both series. Both switch series and Airwave are on last f/w versions to this date.
thanks,
Erik
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
3 weeks ago
I also have this problem. We have to Flex 5700, suddenly one of them has this interface error. I know its been working before.
Differense in firmware can be the cause:
Release 2416 (Bootrom Version: 139) (not working)
Release 2422P01 (Bootrom Version: 147) (working)
Error:
HPE 5700 Switch HP5700-48XG-1 Error in SNMP polling: Unknown error(interface_monitor)
I have contact with TAC regarding other cases with Airwave, I will bring it to them.
Jon
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
3 weeks ago
FYI; FF 5700-32XGT-8XG R2432P06 not working. I have no record of which bootrom version.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
