Network Management
Highlighted
Configuration changes with Aruba Airwave
Hi community,
Can Aruba Airwave gather historical information about the detailed configuration changes on devices, identifying the changes and the user responsible of each change?
Thanks for the help
PS: If you feel this information is useful and solved your question or problem, please do not forget to mark it as a solution and give me some kudos.
Highlighted
Re: Configuration changes with Aruba Airwave
If the configuration changes are done from Airwave, yes, the changes are stored in the device configration log and the Airwave user logs are under Sytem Audit log. If the config changes are done directly on the device, Airwave does not  know the history or user.
