I am trying to configure Kron for backups on my aruba switches but it wont take the commands. Is there an alternative to kron or what method do you use to do automatic config updates on your aruba switches?
disclaimer: we use HPE IMC or Airwave for this... So no experience.
You can try job scheduler. Compare Management and Config Guide, Chapter 14
File Transfer commmands are described in the same guide in Chapter 11.
Regards, Jö
