Network Management
Upcoming community maintenance Oct. 27th through Oct. 29th
For more info click here
Highlighted
Re: Error in CAD Layers
Nope, it doesn't work with another file either.
Highlighted
MVP Expert
Could you try remove the visualrf bootstrap file and check the status.
  • Disable visualrf engine from visualrf>setup page
  • Remove visualrf_bootstrap cache file from server
# cd /var/airwave/cache/
# rm -rf visualrf_bootstrap
  • Enable visularf engine
Pavan
Pavan Arshewar | ACCP
If my post address your queries, give kudos and accept as solution!
NOTE: Answers and views expressed by me on this forum are my own and not necessarily the position of Aruba or Hewlett Packard Enterprise.
Highlighted
No change.
Can it be that the reason for this is changing .dwg files version before upload. I need to get CAD files in AC1024/1021/1018 format, but while doing that I get these messages from AutoCAD:
Highlighted
MVP Expert
What version of dwg file it is showing, when you open the file in notepad?
Do you have any other dwg file to test, before saving it to lower version, make a copy of this original file and try save it as autocad file and check the stauts.
Pavan
Highlighted
I did try it before when I had problems uploading CAD files: http://community.arubanetworks.com/t5/Network-Management/Batch-Floor-Upload-Wizard/m-p/296566#M6762
You said that I have to convert files if I have problems with newest formats.
Highlighted
MVP Expert
Ok, so those files already in AC1024/1021/1018 format ? Could you share your dwg file, I will check in my server.
Pavan
Highlighted
The Original.dwg I cant't upload and in ACAD_2010-Original.dwg can't choose/set wall type.
Highlighted
MVP Expert
You could send file from Airheads message options, top right.
Pavan
Highlighted
Added them as .zip file in previous message
Highlighted
MVP Expert
Hi
I am not able to upload any of the dwg files its looks some issue with files.
Since you are able to upload the dwg files, as a work around we could manually draw the walls once floor provision is done, else we need to get the files in mentioned format and check the status.
Pavan
View solution in original post
