Network Management
Highlighted
Re: Error in CAD Layers
Have a lot of buildings to upload and hoped to skip manually drawing walls. Do you have idea why I cannot upload .dwg files in newer format (1032)?
Highlighted
Update: Sorry, sample file worked suddenly :)
Now that I thought about it I think that my files are OK, I can't set the walls to the AutoCAD sample file (https://knowledge.autodesk.com/support/autocad/downloads/caas/downloads/content/autocad-sample-files.html) either and it is in AC1024 version that I can upload. I didn't do anything to the sample file aside from downloading it, but it works for you and not for me.
