Network Management
Frequent Contributor I
Help me find Airwave's basic down devices report?
What I need to find please is a report that simply shows the "Down Devices" list, and to be able to filter it by folder/device type etc as with other reports.
It would be nice if it also shows the basic up/down devices pie chart from the dashboard page.
I have tried all of the obvious canned report templates and custom report options, but I cannot find a report that gives me basic Device Down info.
There are some reports that give detialed uptime/downtime percentages across many columns - this is not what I need.
Does this report exist?
Re: Help me find Airwave's basic down devices report?
No report like that, as of today, please raise a feature request at innovate.arubanetworks.com, if you do not have access your Aruba sales/accounts team could help. However, you could check that info only real time for now, on the Airwave GUI, by clicking on the down devices, filter it based on the folder or the device type, which I am sure you might already know :-)
-If you got what you need with my answer please give kudos and mark it as solution.
Thanks for your replay Fayyaz, I thought that might be the case.
Anyone else who would like to see this report added, please vote on my idea at https://innovate.arubanetworks.com/ideas/NMS-I-1377
Ack! I just voted it, too.. !
