Network Management
Upcoming community maintenance Oct. 27th through Oct. 29th
For more info click here
Highlighted
MVP Guru
Re: How to Set Airwave Clock
@Tamaz have you tried the ampcli command whilst in the CLI?
ACMP, ACSA, ACDX #985
If my post addresses your query, give kudos:)
Highlighted
Moderator
What browser are you using?  Chrome lets you view the page even if timestamp on server vs access terminal are different.  Otherwise you'll need to open a support case.
Rob Gin
Senior QA Engineer - Network Services
Aruba Networks, a Hewlett Packard Enterprise Company
Highlighted
CLI is not accessable anymore in latest AMP, only Support can access it.
We reinstalled the server with correct time and still no go on the web-ui. Created a TAC case and it turned out the new AMP-initial setup-script changed the local hosts-file for 127.0.0.1 from localhost to whatever hostname we specified in the setup. This made internal services that tried to connect on localhost fail. Aruba TAC solved the problem by modifying the hosts--file directly.
