Network Management
How to edit my switches on airwaves
Hello
I am new to Aruba airwaves and would like to know how i can edit and configure my switches using the software.
I have added some of the switches and can see there set up but just cant find where i can for example change the VLAN or enable/disable a port as we could using the old HP procurve.
Regular Contributor I
Re: How to edit my switches on airwaves
This guide should give you an idea.
https://support.hpe.com/hpsc/doc/public/display?docId=emr_na-a00059667en_us&docLocale=en_US
Ajay Kumar Ravipati
ACMA (V8) | ACMP (V8) | CCENT | CCNA (R&S) | PAN-OS 8.0 ACE
