Network Management
Highlighted
How to get Airwave Serial Number from CLI or GUI in 8.2.6
Hello, we are trying to get the serial number for our Airwave installation but can't seem to find out how.  In the CLI, or what is called a CLI, there are only menu options.  We haven't found any of the options showing the serial number.  Also, in the web GUI we can't seem to find the serial.
Anyone know how to get it from the menu driven CLI?
Highlighted
MVP Expert
Re: How to get Airwave Serial Number from CLI or GUI in 8.2.6
If you get the license , the serial should be there
Thank you
Victor Fabian
Pardon typos sent from Mobile
Thank you
Victor Fabian
Lead Mobility Architect @WEI
Highlighted
You can go to option 11 from CLI menu and type the below command,
# dmidecode
Vishnu
If my post helped you, don't forget to give kudos ;)
Highlighted
In the GUI, navigate to HOME > License.  Under "Licenses", click the license.  A pop-up with the license details will appear with the serial number therein.
Cheers!
