Network Management
IDS Events of IAP in Airwave
Hi There,
I discovered IAP in Airwave 8.2.6.1 in monitor-only mode. I can able to see only IDS events releated to Rogue AP event. All other IAP IDS detections(like client attacks, Valid SSID violation, AP spoofing etc.. ) data is not getting reflected. Did i missed any settings?
Re: IDS Events of IAP in Airwave
Thanks cj,
I have enabled all IDS/IPS settings in IAP.
I have seen IDS data gettings reflected in old Airwave servers(below snapshot). Did airwave removed this feature?
MVP Guru
Does old server have only single IAP added?  I beleive those IDSs events generated from multiple IAPs if I am not wrong.
check bleow command on IAP to configure and display state
#ids
#show ap monitor ids-state
Pavan
If my post address your queries, give kudos and accept as solution!
NOTE: Answers and views expressed by me on this forum are my own and not necessarily the position of Aruba or Hewlett Packard Enterprise.
Hi Pavan,
Everything correctly configured in IAP.
my only query is, will Airwave 8.2.6.1 IDS events supports IDS activities (like Client attacks, AP spoofing etc..) other than Rogue activity? Because, i am only able to see only rogue activity in IDS events tab.
Thanks!!
MVP Guru
Airwave supports IDS events
Pavan
