Network Management
Highlighted
Max Number of devices on Airwave 8.2.7
Can someone tell me what the max number of devices Airwave 8.2.7 can have please?  The last bit of information I can find regarding this is 4 years old.
Sean
Highlighted
MVP Guru
Re: Max Number of devices on Airwave 8.2.7
Pro Appliance : 1500 Devices.
Enterprise Appliance : 4000 Devices
Central Ready Appliance : 4000 Devices.
https://www.arubanetworks.com/assets/ds/DS_AW.pdf
If you have a VM, then it depends on the specs of the VM. The DS includes the physical hardware specifications if you need to compare.
ACMP, ACSA, ACDX #985
If my post addresses your query, give kudos:)
Highlighted
Thanks Craig,
Can you confirm its a maximum of 4000 managed devices and the devices are just AP and not controllers please?
It the document it states 4000 managed devices but I am just a little cautious becasue my Airwave server is coming up to 4000 devices but not all of them are managed, I have appox 1000 devices in monitor only + firmware upgrade.
Sean
Highlighted
Devices in Airwave refer to AP's, controllers and switches. Devices which are added to a group and folder whether Monitored or Managed are counted towards the license usage,
Highlighted
It includes the total devices added on Airwave, which includes both APs and Controller(managed and monitor).
Vishnu
If my post helped you, don't forget to give kudos ;)
