Network Management
Highlighted
Occasional Contributor I
PAPI Packet loss in Airwave
 I have a new Airwave appliance running 8.2.8.1. I have my mobility controllers added, and I'm receiving data. I've noticed under Sytem / Performance, that I have non-zero values in the Average PAPI Packet Loss graph.
I researched this on the community site and read some very helpful documentation on making sure AMON is setup correctly, but the graphs still show packet loss. The Airwave appliance is on the same subnet as the MCs, so there isn't a firewall or routing issue. I used qlog on AMP and it didn't show any problems. I can't figure out why or how packets are dropping. Is this normal, or just a known bug?rrd_graph.png
Highlighted
MVP Expert
Re: PAPI Packet loss in Airwave
If I understand correctly there is no firewall between Airwave and controllers?
In graph we see first two controllers showing zero packet loss , does clients terminating on this controllers?
Default amon buffer size in 8.x code is 1264, compare buffer size`of first two controllers with third & fourth controller in the list which showing packet loss.
https://www.arubanetworks.com/techdocs/ArubaOS_81_Web_Help/Content/ArubaFrameStyles/1CommandList/amon_packet_size.htm
Pavan Arshewar | ACCP
If my post address your queries, give kudos and accept as solution!
NOTE: Answers and views expressed by me on this forum are my own and not necessarily the position of Aruba or Hewlett Packard Enterprise.
Highlighted
The amon msg buffer size is identical across all devices. The only reason that one controller didn't show any loss is because it did not have any active APs or clients.
Highlighted
Frequent Contributor I
+1 on this issue. I have AirWave 8.2.10.0 and see PAPI packet loss on two out of six controllers. The two with the PAPI issues are the two where most all of my APs are terminated. All controllers are on the same MM in basically the same config tree, so the configs are virtually identical. Controllers with and without errors are even on the same VLAN. Is there no way to troubleshoot what is generating this loss?
Highlighted
MVP Expert
Packet loss is not high but we you can try increase amon buffer size value to 1400 and check packet loss status and also make sure server does not have any system resources issue RAM/CPU/load, we can check this detials in performance page.
Highlighted
It was at 1400 before I changed it back to the default size. Still seeing PAPI packet loss in the graph.
I have a TAC case opened as well.
