Network Management
Highlighted
MVP Expert
Re: Problems with Airwave heatmap
Mark,
Are you seeing this issue after upgrade? AMP 8.2.4 is avaialble to download from support site, try upgrade the server and check the status.
Pavan
Pavan Arshewar | ACCP
If my post address your queries, give kudos and accept as solution!
NOTE: Answers and views expressed by me on this forum are my own and not necessarily the position of Aruba or Hewlett Packard Enterprise.
Highlighted
Will the toggle to Metric cause the system to need a reboot?
Highlighted
MVP Expert
Toggling measurment unit will not reboot the server.
