I currently have a network with 10 Aruba 2530 switches. Each switch will have the same configuration with the exception of a different IP in the managment VLAN.
I'm trying to find a way to:
- Push a config to multiple switches at the same time
- Run the command [show running-config] and return the output to a .txt or .config file so they can be backed up in a repository.
Is this something that could be accomplished via SSH / Powershell scripting?
edits: spelling.
