Network Management
Remote SPAN supported Aruba Switches
Dear All Friends,
I am new to here and would like to get your suggestions.
Can you all kindly suggest which model of Aruba Access switch is the best to use to support for Remote SPAN and also stackable?
Thank you ahead.
MVP Guru
Re: Remote SPAN supported Aruba Switches
For the ArubaOS switches, that can be found in the ArubaOS-Switch Feature Support Matrix (here is the version for ArubaOS 16.10).
Remote mirroring is supported on the 2930 and up. From there you can find a switch with the proper specifications (like stacking, ports, speeds, other features).
Hi Herman,
Thank you for your information and reply. I will check and have a look from your provided link. I will check in detail regarding for remote mirroring especially through WAN Link. If you have any suggestion, please kindly suggest as well. I am really appreciated your information.
Best Regards,
