Network Management
Frequent Contributor II
Rename AP from Controller ... is there no way other than doing a reconfiguration?
Want to add an extra bit of info (the last 4 characters of the radio MAC) to all of my (200+) access points.
Is there a way to do this, short of reconfiguring each, one by one?
Re: Rename AP from Controller ... is there no way other than doing a reconfiguration?
You can reprovision multiple APs at once, as long as they are the same model.
ArubaOS 8.4 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
Airheads Learning Videos
Aruba Central Documentation
Sign up for Security Alerts
Aruba Technical Webinars
