Its depend on rule, if it you set rule to discover rogue on LAN then you need to check rogue AP on wired side.
I believe we do not have VisualRF option in Aruba Central but feature is available in Airwave. If you want to contain rogue devices then its a good idea to enable containment option, it will block Rogue AP.
