Network Management
Highlighted
Occasional Contributor I
Rogue Devices in AirWave - best practices
Hi
I have in AirWave a lot of Rogue devices.
What are the best practices? Should I just delete all of them?
Regards
Accepted Solutions
Highlighted
MVP Expert
Re: Rogue Devices in AirWave - best practices
Best practive is to keep low value for rapids retention setting, default Delete rogue value is set to zero days in Rapids>setup page, try set to one or two days and wait for next nightly maintainece to purge all old data. Default nighly maintianence runs at 4:15am everyday.
Pavan Arshewar | ACCP
If my post address your queries, give kudos and accept as solution!
NOTE: Answers and views expressed by me on this forum are my own and not necessarily the position of Aruba or Hewlett Packard Enterprise.
View solution in original post
All Replies
Highlighted
MVP Expert
