Network Management
Highlighted
Rogues from Controller not syncing to Airwave
I am trying to configure rogue detection on Airwave.  Currently on my controller, it is reporting 12 Rogues on the wire at 100%.  I created a rule in Airwave to "Use Controller Classification", Detected on WLAN, Controller Classification="Rogue".  However, I'm not getting any Rogues reported in Airwave.
Any ideas?
Highlighted
Re: Rogues from Controller not syncing to Airwave
Hi, Just add Controller Classification as the condition in the RPAIDS rules.
Detected on WAN + Controller classification means the AP has to met both conditions, if either is no met you wont see any Rogues. to have exat controller classification, Just use one condition and make sure the controller is added to Airwave with ROgue AP polling enabled in the group settings.
Highlighted
Thanks so much for the reply.  I validated my settings and still no luck on getting Rogue notifications.  See attached screenshots of my configs.  I have another Airwave setup at another location with the same settings and everything is working so I'm not for sure what I'm missing here.
Thanks!
Highlighted
MVP Expert
Rogues are getting discovered in Airwave but not matching with controller or no rogues getting discovered?
Did you enable poll local controller option under Rapids>Setup page?
Pavan Arshewar | ACCP
If my post address your queries, give kudos and accept as solution!
NOTE: Answers and views expressed by me on this forum are my own and not necessarily the position of Aruba or Hewlett Packard Enterprise.
Highlighted
Rogues are being discovered on the controller, but are not showing up in Airwave.
Yes, Poll local controllers is enabled under RAPIDS setup.
See attached...
Thanks!
Highlighted
MVP Expert
If rogues itself not discovering in Airwave then need to check if any service is down, under system>status page we see all services status , check if AP watcher service or any other service showing down?
Highlighted
No services are showing down...the below services are disabled:
AMON DTLS Receiver
AW10Migration
Cisco ACS
Cisco WLSE Poller
Dead Letter Exchange Consumer
ElasticSearch
Failover Monitor
FTP Server
Glass Feeder
IGC
Logstash
Master Console
NTP Client
Parallel HTTP Fetcher
RADIUS Accounting Server
RTLS Collector
Safe Migration Parallel Worker
sFlow API
Highlighted
MVP Expert
Are you seeing any snmp thin_ap_rogue timeouts under Controller's Device>Monitor page event section in Airwave? If YES try increase snmp timeout/retries values in Devices Setup > Communication page and poll the controller also try restart AMP services once from system>status page if you are not seeing any timeouts.
Highlighted
No,  I am not seeing any snmp thin_ap_rogue timeouts in the logs.  I did a complete reboot of the server but still nothing.
Highlighted
MVP Expert
To check if any rogue data is been sent to Airwave or not, we can do snoop for thin_ap_rogue topic wait for few minutes and stop the snoop. Collect the snoop file from Download File CLI option.
Go to Advanced> Enter Commands
$snoop thin_ap_rogue
Wait for few minutes
$snoop stop thin_ap_rogue
Download file from Files> Download File > (snoop_thin_ap_rogue.txt) file.
If no rogue data is been sent from controller/IAP open Aruba controller/IAP TAC tikcet .
