Network Management
Highlighted
Simple questions about Airwave.
I am very new to this enviroment and I am starting to get my feet wet in the managment side and I have a few questions.I have 30 IAP-305s and we need better managment so I am exploring Airwave.
I want to intall the Airwave software on a server we already have and just need to understand whats required.
1. How long are the Airwave Licences valid?
2. Where do I find the software?
3. Is there seperate licences for the IAPs and the server that runs Airwave?
Any calrity from someone who has set a system up from scratch would be appreicated.
Accepted Solutions
Highlighted
Re: Simple questions about Airwave.
please find the answers to your questions:
Fayyaz: once you install the software, you will get like around 60-90 days of grace period to apply the licenses. You could purchase the permanent license by contacting your contact at Aruba.
Fayyaz:  You can find the Aruba Airwave software on support.arubanetworks.com, select software and select Airwave to download the software, 8.2.9.x train is the latest version.
Fayyaz: You could just purchase AP licenses, they will work for all controller's, controller based - ap's and IAP's too. basically it is per device that is being monitored is considered as 1 AP license.  Since, you have 30 Devices, you can purchase them accordingly or you could also purchase extra by keeping your future expansion in mind too.  There is no seperate license for Airwave server alone.
hope this helps.
-If you got what you need with my answer please give kudos and mark it as solution.
View solution in original post
All Replies
Highlighted
hope this helps.
Highlighted
Awesome thanks for the reply!
