Network Management
Upcoming community maintenance Oct. 27th through Oct. 29th
For more info click here
Highlighted
Contributor I
Switch Upgrade using AirWave
Good Morning,
I am trying to use AMP 8.2.8.2 to upgrade the firmware of my Aruba switches 2530 and 2930, so I downloaded the required firmware from ASP and uploaded it to AirWave
the upgrade status In progress
but in the Firmware server log in am getting the following:
Sun May 10 18:04:24 2020:     SW-CORUSAUN4OFSW01 Device is upgrading...
Sun May 10 18:04:24 2020: Pass complete for Firmware upgrade job (Sun May 10 18:03:11 2020)
Sun May 10 18:05:22 2020: Starting a pass for Firmware upgrade job (Sun May 10 18:03:11 2020)
Sun May 10 18:05:22 2020: Pass complete for Firmware upgrade job (Sun May 10 18:03:11 2020)
Sun May 10 18:06:22 2020: Starting a pass for Firmware upgrade job (Sun May 10 18:03:11 2020)
Sun May 10 18:06:23 2020: Pass complete for Firmware upgrade job (Sun May 10 18:03:11 2020)
Sun May 10 18:07:22 2020: Starting a pass for Firmware upgrade job (Sun May 10 18:03:11 2020)
Sun May 10 18:07:22 2020: Pass complete for Firmware upgrade job (Sun May 10 18:03:11 2020
 And after a while the process fail.
Can you please advise and let me know if i am missing a step?
Thank you,
Husam
Accepted Solutions
Highlighted
MVP Expert
Re: Switch Upgrade using AirWave
  1. if access-list configured on the switch, we had to add ACL to allow UDP port 69 for tftp in Switch config.
  2. Added ip source interface for tftp for management VLAN using the below command.
# ip source-interface tftp vlan <vlanid>
Pavan Arshewar | ACCP
If my post address your queries, give kudos and accept as solution!
NOTE: Answers and views expressed by me on this forum are my own and not necessarily the position of Aruba or Hewlett Packard Enterprise.
View solution in original post
All Replies
Highlighted
MVP Expert
To narrow down this issue,We can check for more details in /var/log/firmware_enforcer log which is available under system > status page in Airwave and also run $show logging –r (Displays all recorded log messages, with the most recent entries listed first) or $show logging –a (Displays all recorded log messages, including those before the last reboot.) on switch to see if firmware failed at device end.
Highlighted
Contributor I
I checked the switch logging, and i am getting: sftp: Request failed.
I tried to use TFTP and had the same results.
and in AirWave ststus, i am getting:
Downloading firmware failed
Highlighted
MVP Expert
