I will need to upgrade my airwave server to a new version 8.2.10.1 Under CentOS 7. I'm sorry but the process is not clear for me...
I Understand that I should first upgrade it to 8.2.10 Under CentOS6 with the upgraed package.
after that take a backup from 8.2.10 version
make a fresh install Under my server of 8.2.10 Under centOS7
restore the backup on 8.2.10.
I just want to be sure that I can upgrade first directly from 8.2.5.1 to 8.2.10. I saw that from 8.2.7 you should first upgrade to 8.2.9 and after 8.2.10. Thanks to confirm.
If you can provide the details of upgrade steps it would be great.
Ben.
Other question, I saw that we have another
