Hi
I have a client who was a current office network of 192.168.10.0/24 and this routes through to a private network 10.1.10.0/24 in a datacentre with hosted servers.
Default gateways are 192.168.10.254 and 10.1.10.254.
Both networks can currently talk to each other.
I need to bring the private network into the office and allow both networks to communicate with each other.
The private network will be turned off and the servers from there will be brought into the office on the 192.168.10.0/24 network.
I am setting up a switch to allow this and the other company is configuring the routers.
Below is my switch configuration.
hostname "Aruba-2930F-48G-4SFP"
module 1 type jl260a
ip default-gateway 192.168.10.254
ip route 0.0.0.0 0.0.0.0 192.168.10.254
snmp-server community "public" unrestricted
vlan 1
name "DEFAULT_VLAN"
no untagged 32-40
untagged 1-31,41-52
ip address 192.168.10.150 255.255.255.0
exit
vlan 10
name "10.1.10.x"
untagged 32-40
tagged 48
ip address 10.1.10.254 255.255.255.0
exit
no tftp server
no autorun
no dhcp config-file-update
no dhcp image-file-update
password manager
password operator
I have a vmware machine which will be using vlan id 10.
Just wanted to find out if this configuration would work ok.
Jimi
