I want to enable Virtual-ip-ping with the VRRP router but the command is not regonized on the Aruba 2930F with firmware WC.16.10.0007.
To add the command in the VLAN VRRP VRID is not possible.
Anyone a solution?
Topic closed.
I found out that virtual-ip-ping is enabled by default.
