Network Management
Wired Clients discovery in airwave
Hi there,
Can AirWave track the activity of authenticated wired clients on HP and cisco switches? Specifically HP 5310 switches?
If not possible with HP & cisco, can anyone suggest any advanced integration methods to view wierd clients?
Thanks!!
MVP Guru
Re: Wired Clients discovery in airwave
https://support.arubanetworks.com/Documentation/tabid/77/DMXModule/512/Command/Core_Download/Default.aspx?EntryId=31885
Airwave have HPE 5130 device support and we do show wired clients. check above link for more support device list.
Pavan
If my post address your queries, give kudos and accept as solution!
NOTE: Answers and views expressed by me on this forum are my own and not necessarily the position of Aruba or Hewlett Packard Enterprise.
Where can I find the wired clients in AIrwave web UI
