@Aditya_pr wrote:
I am trying to install airwave on my VMware workstation Pro.
While installing i get the first option to set a date. But after all the other processes and setting a static IP to the airwave, while accessing the airwave with the same static IP address i am unable to access it. I get an insecure message for SSL certificate but when i proceed that option i get connection refused error on the browser. Also, at the same time when checking on VMware i get the very first option again to set the Date and Time.
Hi Aditya_pr,
I have installed AirWave on VM Workstation Pro. I got the same errors like you and when trying to access AirWave via HTTPS, I got an insecure message for SSL certificate, when I proceed that option I got connection refused error on the browser and seemed to be stuck there, but when I wait some minutes I got the AirWave GUI. You have to wait some minutes, it is because while a laptop can provide 8 GB of RAM, it isn't as powerful as a server.
Julián
