Network Management
Highlighted
Occasional Contributor I
can not add IAP to Airwave
Hi
I have installed the latest Airwave on a ESX for my Lab and everything seems to be ok , but I can not add any IAP´s to the Airwave.
Tried different things , but the result stays the same.
I can see the IAP under new devices but if I push the add button nothing happens in any case. The same for delete IAP or ignore IAP.
Any hints how to troubleshoot this ?  I suspect a Airwave problem
Regards Markus
Accepted Solutions
Highlighted
MVP Expert
Re: can not add IAP to Airwave
We need to execute from this prompt
root@localhost CentOS7 ~/git/mercury [master]#
Pavan Arshewar | ACCP
If my post address your queries, give kudos and accept as solution!
NOTE: Answers and views expressed by me on this forum are my own and not necessarily the position of Aruba or Hewlett Packard Enterprise.
View solution in original post
All Replies
Highlighted
There is an option in Aruba  Instant to mention Airwave Server in Setting.
Logi into Instant Dashbordh > Setting
Dinusha Chandrasinghe
Network Engineer -Enterprise System Solution @PlexusGlobal
ACMP | ACSA | ACCA | MCSA
Highlighted
MVP Expert
Is it new Airwave installation server or old, are you not able to delete any down device from Airwave server aswell?
May I know the version of Airwave, if your server is in below 8.2.4 version code then you can try recompile code by running make command but before running make , it is better to check
/var/log/httpd/error_log and /var/log/nginx/nginx_error.log logs under system>status page for any error entry while trying to delete or add device.
If your server is newly installed Airwave latest version then first check logs to see for any error and later we can try recompile code but for that you need to take TAC help. We can not run make command from AMPCLI.
Try restart AMP services once from system status page aswell.
Highlighted
Hi
it is Version 8.2.10.1 and it is a fresh ISO install from scratch .
Rebooted the whole VM several times and disabled/enabled AMP without success.
Log shows no specific errors.
btw. i have root access to the Centos , I guess that's enough to recompile Airwave ?
Regards Markus
Highlighted
MVP Expert
 We blocked root access to Airwave shell not sure how you got root access to CLI, if you have then execute command
#make
Highlighted
where do I have to execute make ?
/root/git/...... ?
btw. i was asked meanwhile the installation to add extra users.
Highlighted
MVP Expert
