Network Management
Highlighted
Frequent Contributor I
deleting devices on Airwave
Hi Comunnity
I use Airwave 8.2.4.1 and I am trying to delete some devices from one group. Initially I had 31 devices and I deleted 13. I can't delete the rest 18 devices. Any recommedation?
Best regards
Karlink
Accepted Solutions
Highlighted
Moderator
Re: deleting devices on Airwave
Are you deleting individually from the Device's manage page?  Or are you doing bulk deletes from a list view?  If the device's aren't getting deleted after you'd set them to be deleted, then next step should be opening a TAC case so that they can investigate if there's any locks in the database for those objects.
Rob Gin
Senior QA Engineer - Network Services
Aruba Networks, a Hewlett Packard Enterprise Company
View solution in original post
All Replies
Highlighted
Moderator
Rob Gin
